IBcarguy's avatar
IBcarguy
2006 Suburban for towing?
How well would a 2006 Suburban 2500 with the 6.0 liter pull a 33' TT weighing 6300 lbs dry? It has the 4:10 rear end. A friend had a silverado with this motor but had 3:73 gears and it would constantly downshift/upshift on the slightest of grades. I've read the lower gears is much better. Anyone pull with one of these?
  • Thanks for the response. I also read that these motors like to rev so don't back off when it sounds like it's winding up pretty tight. He also warned me that I can expect 8mpg when towing, which I expected. I wish I could afford a Duramax, they just can't be beat as a tow vehicle.
  • I pull with a Silverado 2500 crew cab 6.0 4:10 rear. I have the six speed trans. Can't use 6th gear, most of the time I shift it manually when towing. Does a decent job as I'm around 70K in tow miles over the last three years. Head winds are a problem though, only a diesel will cure that. I'll be posting a oil analysis a little latter on this motor. I think the 6.0 will run for ever but they are gas hounds that's for sure!
