Lindsay Sorensen wrote:
Hello. We have the same trailer as you do and the hot water heater switch to ignite the flame is inside the bathroom beside the bathroom light switch. You turn it on and the stitch will turn red as it tried to ignite and then will click off and then back on automatically until it lights. If you leave it on it will hear as needed. If it doesn't ignite after a bit of trying then turn the switch off for a min then try again. Hope this helps!
That was optional. The OP might have the same water heater that I have in my 2004 model. Two options that I don' have and wish that I had are...
1) auto ignition hot water heater
2) electric element heater in rooftop A/C unit for chilly nights where I've got shore power and don't want to use propane.
