Dakota98
May 22, 2015Explorer
The sticker on the door jamb of the TT is accurate @ 5,126 since that figure is "as built"
Your TT loaded weight will be closer to 6,200 + and your tongue weight should be a minimum 10% of that figure ( 620# )
Yes, take the TV to the scales, I believe the figures you are currently working with indicate that you have about 1,835 lbs. "payload capacity" I think that may be a bit high.
