davekro
Aug 05, 2015Explorer
2007 Fleetwood Element- Cobalt: Advice needed
I will be helping a friend ready his just purchased 2007 Fleetwood Element- Cobalt for it's maiden voyage (to Burning Man). He is new to PU trailers. I had one 30 years ago. :oO
I'd really appreciate any model specific (or general) advice on the following:
1) Tie down of Roof for high wind:
Due to up to poss max 40 mph winds, he wants to devise a way to make it more secure. Any suggestions or warnings? My thought is just putting eye bolts at corners of roof (if even possible??) to tie down w/ rope might cause to much downward force on lift system? Maybe use ?8' long 2x4's at each corner of roof for support , THEN snug roof down with ropes to ground?
I will go see the camper for the first time later today to brainstorm ideas with him, but wanted to see if there was any tent trailer experienced ideas or warnings first.
Rather than trying to attach corner ropes directly (way easiest for use) would it be better to build a 2x4 frame to attach to or set atop the roof to attach ropes to? I don't think he cares about how it looks, just the function for BM high winds.
2) Alumi-Tite roof:
I have read of leaking issues with this roof (at the rails). Any recommendation for a good way to caulk or seal rails? He does plan to mount a carrier on the roof for two bikes. No Idea if previous owner used mounting rack on roof, but he did have it set up for 4 wheeling (raised frame and larger wheels). My friend had him put smaller wheels back on.
3) Stability at camp:
We were going to replace the pad tongue jack with a wheel, but for stability, he decided to keep pad for first trip. Any other ideas besides using blocks of wood under each corner and the tongue jack?
4) Can an 18 volt cordless drill be used to raise (and lower??) the top? What adapter/connector is needed? Any cautions on this, like stop before full height, then use crank?
Thanks for any help I can share with my buddy.
2) Alumi-Tite roof:
