jbres
Dec 20, 2014Explorer
2007 GMC 2500HD HEATER CORE PROBLEMS!! help
My trucks is a 2007 GMC 2500HD with the 6.0 gas job in it. Truck only has 76,000 miles and I have had it a little over a year. I bought the truck because of how pristine and perfect it was kept. Clean as a whistle, and rust is non existent. It is not my daily driver, I usually run it around 1-2 times a week during the offseason, just to keep it flowing and running.
Well today, all of the sudden on the highway, I start getting a terrible coolant smell coming through the vents. Entire truck windows were terribly fogged up, and heat didn't seem to be working as powerful. Made it home, and found coolant leaking through that rubber drain tube which is underneath the A/C compressor. Coolant not leaking anywhere else whatsoever. Is this a heater core problem?
I follow my owners manual step by step and do preventative maintenance per the book exactly.(I am anal about my truck) Coolant was flushed by the local tire discounters one year ago (only went there bc I had a gift card) and they flushed it with Valvoline max life yellow universal coolant, as they highly suggested me getting the "Dex Death" outta there.
So, I was not the original owner of the truck, but is there any extended warranty GMC has on the vehicles with this low of miles? Should I try and fight Tire Discounters on not using the "Dex coolant" which after I researched, I agreed Dex has quite a few problems in itself. (my 03 Tahoe I use DEX in, and in the overflow tank I can literally see where the Dex has gummed up over the year)
Or any other opinion suggestions on what to do? I have heard this repair can cost upwards of $900 bc of labor involved.
