rowekmrExplorerJun 01, 20192007 Navigator No Brake Fluid at CaliperHello just got a 07 Navigator with 117k miles that pulled to the right when driving then to the left when brakes applied. I found out that the passenger side caliper pin were frozen and pistons kept ...Show More
Grit_dogNavigator IIIJun 02, 2019Appears OP has replaced both front flex hoses already, or did I misread?
Related ContentAir Brake Calipers....YIKES !!! (UPDATE)Brake CalipersAnti-seize on brake caliper bracket?NavigationReplacing brake calipers
