rowekmr
Jun 23, 2019Explorer
UPDATE:
Shop diagnosed a bad ABS Pump aka HCU. I just changed on in a Mountaineer so didn't think it could happen again. I actually didn't believe the shop but gave them the go ahead.
New the HCU was 800 my cost (1,000 retail) but the shop found a good used one locally for $75 and installed it and bled the lines. I was told on the Mountaineer that the ABS pump needs to bled itself with Ford software but this truck stops fine.
Only issue is if it sits for awhile and is started the ABS light comes on but all other starts for the day it stays off. Shop manager when told of this believes the ABS module needs to be programmed (they did on the Mountaineer).
I will find out about the programming later this week.
