Camper8251's avatar
Camper8251
2008 AF 811 Battery size question
So I have an AF811. What is the stock size battery that comes with these?
What is the biggest size that I can put in there without modifying the battery tray etc?
I had two 6volt AGM lifelines I put in there years ago and need to replace them, don't have the money to buy another set and cant recall what was in there.......
Thanks
Any Montana folks around here? Just recently moved to Gallatin Valley MT.
    Ditch the tray and you can fit two Group 31s
  • RICKIM's avatar
    RICKIM
    Explorer III
    My son has two group 31 Lifelines in his AF811. That's the max size that will fit in the tray.
    Good luck,
    Rick
  • Sorry to hear that you couldn't make it to Glacier its a beautiful place. Might be for the better though, they have a pretty big fire up there and the best road is closed. Going to the Sun. Plus its pretty Smokey as well.. Thanks for the quick response!
  • If you had 6 volts in there at one point, you should be able to get group 27 12 volts no problem. 160 minutes reserve capacity each.
    We were headed for Montana (Glacier) but we ran out of time. Turning round at North Dakota.
