dadmomh
May 10, 2013Explorer
Not sure the answer you got was correct...or that my thought is correct, but here we go. I think it's not glued down due to the flexing of the trailer not only during transit, but even set up. If the whole thing is glued down, I think it would pull loose and maybe cause more of a problem. When we toured the FR plant a couple of years ago, they did not glue. You would either glue just around the edges or use a staple gun and then trim molding over that.
