Halmfamily
Aug 08, 2016Explorer
I have an 08 Duramax, see sig, and it has been flawless. Pop the hood on both truck and you will see the Duramax is not as complicated as the PS. I had a PS and it was nearly impossible to get your hand I. The engine to work on. My Duramax I can almost close the hood with me inside.
My truck just turned 130000 miles and has been in the shop once, to repair a leaky tranny cooler line. GM has a bulletin out on this issue so check the truck to see if it's been changed out. The leak is a the cooler in front t of the radiator. The OEM had plastic fittings and the new hoses use metal.
Love my Duramax just with the truck looked as good as the Ford.
44,068 PostsLatest Activity: Jun 10, 2026
