stew47 wrote:
Ok after reading the forums about those topics I'm almost sick to my stomach. A 25000 bill? I just don't know what I would do. Does duramax have a high pressure fuel system? 10 grand to fix?
Not the year your looking at. They had CP3 pumps which were good pumps. Expensive to make, but good pumps.
Let me say this. The HPFP problems weren't so common. I wouldn't say rare, but not too common either. The big problem was the expense. About 15 big bills give or take. So if it was your turn in the barrel it was devastating.
The turbo problems weren't the same way. They had a LOT of turbo problems and that's why Ford went to the single wheel design in 2015. That ended the problems like NOW. No more common problems with the turbos on this engine.
There are other problems with that early engine like the plastic oil pan. I thought it was a good idea at first but it didn't work out for them. They didn't use the correct type of plastic so there were problems. Another problem was bottom end failures because of the tangless bearings. Pretty rare but like the HPFP, when they went, it took out the whole engine.
And GM does not get off scott free for the engine you're looking at either. They had a LOT of DEF tank level problems. The stupid level sensor would not read correctly and it would limp the truck. I think they fixed it with new sensors and software.
No matter what you buy be sure it's checked out very well by a trusted mechanic.
Good hunting!
On edit: Never mind about the DEF sensor problem. That is later and NOT the year you're looking at. Sorry about that.
