The LeRoys wrote:
I just picked up a new to me 2008 E350. Before I drove to get it, I had a Ford garage look it over. The only thing they could find wrong was that it didn't have TPMS sensors. This leaves the dash light on all of the time for the tire sensor error. Can any tire shop re-install these sensors or does it have to be done at Ford?
Is there an aftermarket system that is better than the factory system? If so, can I just disable the factory system & light?
Slightly confused here......
Did the vehicle have TPMS sensors originally - where did they go?
Is it over 10,000# GVWR? TPMS not required at that weight, but then, why is the warning light activated?
Sounds to me like you need your dealer to replace the OEM units.
