the quote "easiest way to turn the light off "is to pull the instrument panel out which of course means you need to pull the -DASH Apart--and loosen the instrument cluster--- find out which bulb it is (it will say on back of cluster)and just twist it out --and then put the whole dash back together --that's " the easiest way "to do it
and I strongly disagree that the factory system is the BEST SYSTEM..
l Have the Doran pressure pro --and it is made in the United States of America --(Cincinnati) and you get a monitor that mounts on the dash and you can buy whatever Number sensors (pretty sure six is what you would need )and it can tell you exactly what the tire pressure is --and it will give you a warning if the tire pressure starts to go down slowly ,or fast --and it will monitor the tires all the time or only have the display on when you have the key on.
It is slicker than anything and by far the best system--(after using it for last 6-7 yrs )and made in the USA!!!
