- hinterlandExplorerThis is the 2008 855, maybe built 3 years from 08 to 2010. It's 9'4" and the dry weight shows 2870 lbs and wet shows 3275 lbs
- JimK-NYExplorer II
Bert the Welder wrote:
3600-3800lbs loaded up. What's your truck rated to carry?
Not even close!!!!
The smallest EC has a dry weight of 3380. With propane and a full water tank the weight will be just shy of 3800#. That does not include options such as an A/C, awnings, generator, second battery or solar. Also add 1000# for cooking gear, bedding, towels, tools, air compressor, cleaning supplies, leveling blocks, lawn chairs, BBQ grill, food/drinks, clothing......
The smallest EC is likely to be in the 5000# range loaded for camping. When calculating gross weight don't forget to add the weight of passengers, stuff you might carry in the truck, tiedowns, fastguns, bed mat.....
You need a dually!! - Bert_the_WelderExplorer II3600-3800lbs loaded up. What's your truck rated to carry?
44,055 PostsLatest Activity: Dec 23, 2025
