oakbowery wrote:
e-light wrote:
I dont own a 6 L GM, but it does have a very good reputation on this forum.
How does that 6.4 do pulling that 5er you have in your signature? Looks like that 5er weighs over 10k unloaded. Looks like the 6.4 has about the same torque as my stock 24V Cummins.
It does great...the 5er in my sig is about 12K loaded with about 2K pin weight. The 6.4L handles it perfectly. I set the cruise on 60 mph and let the computer do it's thing. On flat ground it runs about 2100 rpms in 5th gear. It will rev to about 3000 rpms in 4th gear up medium size hills (small hills will stay in 5th), once the TC locks up it will run about 2500 at 60ish mph in 4th. The computer does an awesome job of holding 4th up the hill and then will upshift back to 5th on the downside. Also using tow/haul and cruise the computer will downshift and rev going downhills to help keep speed in check. On large hills/mountains (the Smokey's are the toughest my truck has been on with trailer) the computer will downshift enough to hold gear without over reving, but will not hold 60 mph. This is by design by the RAM engineers to keep the engine from working too hard. To overcome this, I just used manual gear selection and I was able to cruise right up the large pass between NC and Tenn at 60 mph, no problem. Could have went faster...
For a gasser I don't think it gets any better than a HD RAM and the 6.4L. It actually does better on fuel economy with my heavier 5er than it did with my 8000 lb TT. I got 10.6 mpg on a 240 mile round trip from Louisville to Russell Springs KY a couple weeks ago. And there is little flat ground in between. Not large mountains...but up and down hills the whole way. If used purely on flats the truck would do real good on fuel economy.
As I've mentioned before I have 0 buyers remorse with my truck. It's been perfect and I love it.
