Mike_Up's avatar
Mike_Up
2009 -2014 F150 XLT Crew 4WD "LT C-Load Tire Option"
I'm trying to find the correct air pressure to air my new LT 275/65R18 E1 tires to.
Discount tire is telling me 41 psi which I know is under inflated by the noise, tuffer rolling resistance, poor mileage, and vibration it created.
BFGoodrich is telling me 55 psi which would be correct if my OEM P series tires were had a load rating for a LT tire but they don't they have a load rating for a P tire.
P tires rating have to be lowered 9% due to a regulation if the "P"assenger tires are put on SUVs or Trucks to handle the higher ride height, truck applications, and possible overloading.
So if that the case, the rating should be 47 psi on the new LT E1 tires I bought.
Load E and Load C handle the same weight per psi, up to the C load ranges max of 50 psi.
So those who have an XLT 4WD Crew Cab with the LT275/65R18"C" option tires, what's your door jam placard say to air your front and rear tires at. I really think it's 47 psi.
BTW, I did air up to 55 psi, the ride, noise, vibration, and mileage mirrors my old OEM P series All Season tires but the tires a bit stiffer as one would expect.
I'm fine with airing to 55 psi, but I'm thinking 48 psi is the correct psi.
My OEM P tires are rated at 2601 lbs at 35 psi (max load), my new LT275/65R18E tires are rated at 3415 lbs at 80 psi (max load) and rated at 2400 lbs at 47 psi.
The OEM P tire rated at 2601 lbs at 35 psi is for a car only. 91% of that rating is it's true rating on an SUV or Truck. That rating is now 2367 lbs at 35 psi.
So 47 psi on the LT equals the same load rating as the P series at 35 psi.
So are your tires all rated to be aired to 47 psi??
BTW, here's Firestone's Tire load/size chart. Couldn't find one for BFGoodrich.
  • Load range E tires are 80 psi, look on the sidewall, Chevy 2500s with these tires recomend 60 front and 80 rear;
