flyncold's avatar
flyncold
2010 F450 Jerking/Bucking
I have read several posts throughout the internet stating violent jerking and bucking on the F450. I found these posts because i am a victim of the bucking and jerking. Looking to see if anyone has an update on what is taking place. Here is my situation
2010 F450 with 55k miles on it. Pulling a 4 horse gooseneck16ft Short Wall weighing about 16k empty. i have tested the trailer with and without trailer brakes hooked up. doesn't matter so trailer brakes are not the problem. I just bought this trailer and it is much heavier than my previous trailer. Previous trailer weighed about 5500 pounds empty and never even knew it was behind me. even when it was loaded with 4 horses it didn't phase truck. This trailer has done it since I pulled off the lot. has to be associated with the weight but have not pulled this trailer with any other truck. Only happens with my truck during the braking and mostly below 15 mph.
I hope someone has found a solution other than trading the truck off.
Thanks
  • So it happens when braking?
    What about if you apply the brake manually, does it happen?
    You might try strapping a video camera pointed to the hitch, and try to duplicate the problem, and see if it has something to do with the hitch, it might be cracked or wiggling or something?
    Just tossing out ideas. Normally the truck should not be pushed around by a trailer of nearly eual weight.
    Fred.
  • Any reason you don't think it's the trailer?
    Could be something simple as not enough weight on the goose neck.
