JohnG4706
Sep 19, 2014Explorer
2010 Toyota Sequoia
I've found a couple of 2010 Sequoias in my price range. The following questions:
1. Both have the 5.7L engines.
2. One is a 4WD and the other 2WD. Does the 4WD reduce the MPG's? If so, by how much? Is it worth the loss of MPG's to have 4WD? If you run in the 2WD mode does that give you better MPG's?
3. I've never had a 4WD anything. Are they more prone to mechanical problems vs the 2WD?
4. The 4WD is also capable of using Flex Fuel. (I'm not sure about the 2WD.) From what I've been able to read, while the Flex Fuel is cheaper/gallon, the MPG's are about 2/3 of what the unleaded gas yields. And, in the long run, the Flex Fuel is more expensive when compared to gallons used vs distance. Would being Flex Fuel compatible have any effect on my MPG's if I stay with unleaded only.
Thanks.
Thanks.
