Aaronsmity
Apr 12, 2018Explorer
2010 Yukon XL 3/4 ton vs 2007+ Tundra
Found a local Yukon XL 2500 6.0L 6 speed with 175k miles listed for 11k - From my research I see curb weight is around 6500 with towing capacity of 9600.
I was originally looking at a 2007+ Tundra Crewmax with 6 speed but have found that getting the crew cab and doing the math I would exceed the GVWR of the Tundra by a few hundred pounds loaded.
I cannot find the GVWR of the 2010 Yukon XL 2500 - do I run into the same issue here or is it a better GVWR relative to the Tundras? With the trailer loaded I am estimating a gross trailer weight of around 8000lbs and tongue weight around 1,000.
