Mvander
Sep 02, 2014Explorer
waltah wrote:Mvander wrote:
The 5.0 has the same HP as the eco(minus 5) but you will have to access it differently.
quite the gap in torque across the entire rpm range. the engines arent comparable, they were built for different purposes. The 6.2 is more comparable to the EB than the 5.0
Lot of threads about HP VS. Torque. If you stomped on both of them with a similar load the results wouldn't be much different at the top of the hill. The eco would run generally lower rpm though.
