Mvander
Sep 03, 2014Explorer
missionman wrote:Mvander wrote:waltah wrote:Mvander wrote:
The 5.0 has the same HP as the eco(minus 5) but you will have to access it differently.
quite the gap in torque across the entire rpm range. the engines arent comparable, they were built for different purposes. The 6.2 is more comparable to the EB than the 5.0
Lot of threads about HP VS. Torque. If you stomped on both of them with a similar load the results wouldn't be much different at the top of the hill. The eco would run generally lower rpm though.
There can be lots of threads about anything, I have owned both trucks with each of the drive trains that are in discussion.
Riddle me this, on the same 7% grade highway under the same load and weight. Why does my EB hold 65mph in cruise control and my 5.0 downshifted multiple gears and slowed to 40mph for the entire climb? Your argument is as ridiculous as the guy saying his 5.0 doesn't downshift on hills in 40mph winds. I don't live in indiana, I travel and camp the Adirondack, finger lake, white mountain, and Appalachian regions.
I've owned both, I've hauled heavy loads in the bed with both, I've towed heavy with both, I've towed the same highways with both.
Have you?
I don't know why your 5.0 truck couldn't keep up speed. Maybe you didn't push the gas pedal hard enough. Makes sense that it down shifted though, that's what its supposed to do.
Not knocking the eco boost. I really like them and have driven many granted I have not done the back to back testing. Both those motors do the same amount of work over time (or very close) in different ways. The eco boost feels more relaxed because its not spinning quickly. The driver doesn't feel or hear the increased cylinder pressures like they feel and hear the higher RPM of the V8.
These charachteristics make some people feel like the truck is pulling "effortlessly" when really it is working just as hard to do the same work just in a more pleasing way to some drivers.
