MitchF150
Sep 19, 2014Nomad
Going over the pass to Eastern WA with a #5000 TT and my old 97 F150 with the 5.4 was a good tow.. I was in second gear and pulling 3500 rpms and going 55 mph, so it was fine..
Towing the same TT with my 13 Ecoboost I'm in 4th gear, pulling around 2800 rpms going 60 mph.
You'll need more rpms with the 5.0 (it has more power than the old 5.4) compared to the Eco, but you'll get up the hills as long as you don't mind pulling in the higher rpm range while going up the grades.. You will probably be in 3rd gear and pulling around 3500 rpms to go 55-60 mph.
It's still all guesstimates of course, as no one can determine your towing comfort level and what you consider a "comfortable tow"..
Will you be under "ALL" of your trucks weight limits with that trailer? Who knows?? But my own opinion is you'll be maxed out on GVWR/payload for sure.. I'm within #600 of my trucks GVWR and only #400 from my trucks rear GAWR with just a #5000 LOADED TT and I've got the Max Tow F150 with an Ecoboost.. :)
So, until you get some actual truck weights to find out where you are and go from there, it's only guesstimates..
Good luck!
Mitch
Good luck!
Mitch
