Searching_Ut
May 24, 2013Explorer
The brake controller on the 2010 and 2011 Dodges isn't the same as the one in the 2012 models. In my opinion you'd have to be crazy to install a factory unit in one of those year trucks as it's beyond bad, it's horrible. The only control you have for it is gain, and the gain control is all but useless. If you have a factory installed controller you're going to cry if you ever have to drive on snowy, or even gravel roads as the adjustment range is all but worthless. On my old trailer my 2011 couldn't be adjusted high enough to lock the brakes even on gravel roads. With my Timber ridge, it will lock on pavement at two or three, and locks on gravel even when set to zero, which obviously isn't really zero.
If you complain to the dealer they will just off the record mention they "Have issues"
44,056 PostsLatest Activity: May 04, 2014
