2012Oudoorsman
May 25, 2013Explorer
Cummins12V98 wrote:2012Oudoorsman wrote:SJR wrote:
I have the factory controller on my 2010, all the displays I need are shown on the controller itself, they also show on the dash. So to answer your question, if the 2011 is the same as my 2010, then you don't need to see the display on the dash everything you need will be displayed on the controller itself.
I do have the OEM controller installed by factory, how do you select heavy or light electric brakes. All that's on my controller is gain +and -, and the manuals slide co troller for the trailer brakes
If you would list what your truck is you might get an answer!
My controller works great, nothing is wrong and shows up in evic as it was installed by the factory before I purchased my 2012. I just don't see how you can select between heavy and light electric without the evic as that's where you can choose. The brake controller mounted in the dash only has the gain settings with a digital readout and the manual slide. How can you know which mode your in or even change it if the controller won't tell you this. I happen to like mine very much and works great and will easily lock up trailer tires. But I have read where some don't like it so I was letting the op know about this
44,056 PostsLatest Activity: May 04, 2014
