jrichard
Jun 19, 2013Explorer
CADreaming wrote:
Spent several weekends listening to TT salesmen and found a trailer hubby and I both like -- a Lance 1685. Now we need a reality check.
Tow vehicle is a 2004 Tundra SR5 V8 Double Cab, 4x4, w/tow package. Weighed weight is 5500 lbs with shell, bed liner, one person and a 1/3 tank of gas (add in one average size husband,one 45 lb Border Collie, more gas and a WDH). Tow capacity is 6600 lbs, GCWR 11,800. Tongue wt 690 lbs.
The Lance 1685 is 3405 lbs unloaded (I read somewhere that the Factory Weight is 3877 lbs with full propane, batteries and spare tire), hitch weight 275 lbs, GVWR 5400 lbs (CCC is abt 2000 lbs).
I've crunched the numbers several times and, while it's a little on the "high side", it seems do-able. What am I missing?
Looking just at the info you provided, you appear within limits. 11800-5500 = 6300 lbs left in your GCWR. Why do you think you're missing something? (If you're looking at the numbers of the OP, his truck is entirely different than yours...you have the old style small Tundra with the small motor). With all 1/2 tons and Toyota in particular, the limiting factor is usually payload capacity. Since you're already carrying a shell, you should take a look at your capacity and how much you're already carrying.
