Target13
Nov 03, 2014Explorer
camp-n-family wrote:
I have a 2013 31BHPR but it is in storage down the road. I can swing by tomorrow and measure if nobody else can before then.
Mine has never leaked at the storage doors but I do get a bit of water that sits in the bottom of the frame where the screws are. I saw that as a potential leak so I covered the screw heads with silicone caulk. Is the wavy bit of the panel at the top or bottom of the door? One thing I found odd is that there is no caulking around the door panels and the frame it sits in. You'd think water would get in between there and damage the doors like you see. I considered caulking each of the doors for this but mine seem to be fine.
The drip cap looks like a potential fix but could you still fully open the door and use the latch once it's installed?
The wavy part is on the inside of the door...closer to the bottom.
I am not certain about the clearance. I guess I would rather deal with a dry door that wont stay open.....than rot and mildew/mold.
44,066 PostsLatest Activity: Apr 16, 2026
