fosstugz wrote:
PUCampin wrote:
Not sure I am following, is the lag you speek of towing or empty? Also, cold or warm I think should not make a difference in pulling away from a stop.
I occasionally experience "lag" from a stop in my Expy, because it hasn't shifted all the way back to 1st, because I did not come to a full stop (it won't shift into first unless I come to a complete stop) If I roll the stop, it often tries to pull away in 2nd.
My Expy EL came with 3.73 from the factory, they play very nice with the 6 speed. The GM and Ford 6speed ratios are almost identical so I imagine it would play fine for you too.
Also remember we have small block overhead cam V8s in our trucks. The 4000 rpm range is where they make their power, they are designed to run here and will do so, for a long time if necessary.
When I'm towing from a dead stop, when its cold, she rpm's up a goes when I press the accelerator. When I drive home through town after being on the roads for hours, I press the accelerator and she rpm's up a bit and barely goes. Like the TC/clutch doesn't want to lock up and go. I am not by any stretch knowledgable on tranny's, but I liken the experience to having the clutch pedal on a manual transmission halfway to the floor until I'm doing about 15, where the power kicks in and things seem to link.
Not sure I understand what you are talking about -- my '10 Suburban does not do that. How are your transmission temps when that issue occurs? Are you towing with the tow/haul engaged? I have overheated a transmission in the past (not on this truck, fortunately), and it resulted is sluggish performance even with the engine revving.
