fosstugz's avatar
fosstugz
2012 5.3L Yukon XL
The Mrs. and I are looking at stepping into the TT realm with our two little ones. We've got a new Yukon XL with the 5.3L package. I'm unsure about the ratio, so i'll have to check the sticker at home. Initially, i didn't think towing the trailer's we've been looking at with this rig was going to be an issue, but the more I read, i'm starting to go into panic mode.
I'm expecting to do the usual upgrades including LT tires, WD hitch, brake controller, sway control and air bags. Potentially the trans cooler.
The TT's we're looking at are either the Windjammer 3006WK (6,984lbs dry/877lbs hitch weight) or the Laredo 303TG (7,473lbs dry/905lbs hitch weight). Granted, these things are pushing 36ft, and that's scary enough.
I'm think I'll be pushing the GVWR limit on this ride, TT dealer says no problem, but that doesn't leave me with the warm fuzzy feeling inside.
Basically i want something in a BH over the 29ft mark with nice finishes inside. We've looked at a lot, and these two seems to fit our bill, but may be outside of the Yukon's survivability.... I don't want to destroy a tow that costs twice the trailer.
What do the experts say?
  • I'd go a little lighter and shorter if you have to travel in open country (wind) and/or freeway much. Also, you probably won't be able to stay within the burbs weight ratings with those trailers and a few kids and stuff. Maybe doesn't bother you.
    It's always tough to say no but I think those trailers are beyond the comfort window for a 1/2 ton suburban. But people do it every day.
  • We went that route when first getting into rv-ing and bought a 33ft dutchman 4 bunks huge slide out. Great camper but our new one is a 31 ft passport ultra light. I am so much happier with this camper. Close inside to the dutchman but a whole bunch lighter. We travel a lot so the lighter trailer is all we need and painless to tow !! By the way have been pulling my trailers with suburbans for a long time !! I love them!! Dont be afraid to look lighter!! A little more togetherness is a good thing.
  • Unless something has changed, one of the limits you will run into is the 1,000lb tongue weight limit. The hitch on the Yukon XL is integrated into bumper and not replaceable. It flexes significantly when using a WDH. We towed for 3 years with a 2008 Yukon XL Denali (~7000lb TT) and never felt completely comfortable. The Denali had 1500 chassis with luxury ride, perhaps your Yukon is a 2500 model? The LT tires will help tremendously (we never changed the factory tires). I think it might tow those trailers, but you may not be comfortable, especially in wind.
