klr650goldwing wrote:
If you were buying this truck how many miles would cause you to shy away from the truck?
1; seriously; 1
The first to early 15's had problems. Now the fan bois don't want to hear this but it's true.
They had turbo, high pressure fuel pump, radiator, glow plug and some lower end bearing problems.
Out of those 3 the HPFP was the most troublesome. 15 grand or so to fix that little mistake. The radiator came it at about 2 grand or so to fix. The glow plug problems will cost you a new engine.
2015 on up they changed a lot of those problem parts.
If you're set on a Ford get the 2015.5 on up. The later you go the less problems they had.
