Fordlover
Jul 08, 2018Explorer
AlmostAnOldGuy wrote:
In June of 2012 I ordered my truck outfitted the way I wanted and took delivery in August. Per signature it is a 2012 F150 Max Payload.
Have really enjoyed the truck.
Pros:
- Electronic steering rack - drives straight and true and has the lowest sense of driving fatigue of any truck I have driven.
- Quite ride.
- Very comfortable and supportive seats. With my wife's urging I sprung for Lariat / leather and it fits my backside.
- Great low end torque and plenty of hp. Never lacked for power and as prior rig had an 8.1L I have an idea what a strong gas engine is like.
- Integrated braking trailer works very well. When following owners manual to set the controller it performs an excellent and well controlled stop.
- Well matched to my trailer.
- Unloaded gets better than 19 mpg running between Portland and Seattle (60-70mph). Given the trucks capabilities I consider this very good. With the 8.1L was about to 12mpg.
Cons:
- Engine braking is weak. Tow haul mode does a good job of shift management, but the engine is limited in this space. Has not been an issue as I pay attention as I head into a long downhill run (brake to lower speed, release, repeat as needed) and when I apply brakes the integrated brake controller works well. The 8.1L held better.
- As an early EcoBoost I had the condensation issue. Ford's fix to reduce the efficiency of the intercooler has worked fine and have not noticed any downside. Could spring for aftermarket intercooler but do not see the point unless I move to a hotter climate.
- Have had dealer replace (under warranty) front hub 4x4 mechanism twice. Apparently 2011-2014 rely on vacuum to stay disengaged and have had issues with insufficient vacuum.
Have been happy with this truck and plan on keeping it a long time. Only mod I am adding is a catch can which is something I would do on any direct inject gas engine to keep intake valves clean. Only reason I have held off this long is I have not wanted Ford to complain about a mod if I needed warranty work.
Recent photo on road trip in SE Oregon
And I want to acknowledge my thanks to SkipnChar for his help in deciding on this truck. Have not seen you for some time on here and wishing you well.
Stu
Thank you for the update, I'm happy to see these Ecoboost trucks performing so well and I remember when you got the truck way back. I came really close to following your lead with a Max tow F-150 but the Explorer held together too well, so we delayed new truck until a new trailer required it. I also haven't seen Skip around for a long time, and also wishing him well. Same goes for SurveyorJP I think it was...
