- hkkarlsson96ExplorerHere's a good article on understanding your trucks tow capacity!
https://towingpeaceofmind.com/forums/topic/towing-within-your-trucks-tow-capacity/ - wing_zealotExplorer
KD4UPL wrote:
No, I'm suggesting the tow rating is not established with a flatbed trailer. Per J2807 standard, Its established with a high wall trailer with a 65 Sft frontal area; completely opposite your statement.wing_zealot wrote:
KD4UPL wrote:
You apprently aren't familiar with the SAE J2807 standard, which is how truck ratings are established, or you would never had made such a ridiculous statement.
..There are many different kinds of trailers: flat bed, dump, horse, cargo, boat, equipment, cattle, and RV. They all have their differences. A hard sided RV trailer is by far the most challenging. They have a huge frontal area, a high percentage of tongue weight, a large side "sail" area to catch wind, and very limited ability to adjust the weight balance. The same truck that might pull an 8,000 pound boat very well might be a struggling hand full with a 6,000 pound RV.lo
So, yes, your truck can pull 11,500 pounds. If that's a flatbed load of bricks or a dump trailer load of gravel you're probably fine. If you're talking about a hard sided RV I wouldn't even want to tow 9,000 pounds with a 1500 series truck.
None of my statements are ridiculous. Their are multiple types of trailers, they do have different physical characteristics and quirks, they do tow differently. Wind resistance and tongue weight are absolutely factors that must be considered in how suitable a tow vehicle is.
Are you suggesting that a trailer that vastly overloads the rear axle, tires, and hitch is just fine as long as it weighs no more than the "tow rating" of the vehicle? - wing_zealotExplorer
Are you suggesting that a trailer that vastly overloads the rear axle, tires, and hitch is just fine as long as it weighs no more than the "tow rating" of the vehicle? - KD4UPLExplorer II
Are you suggesting that a trailer that vastly overloads the rear axle, tires, and hitch is just fine as long as it weighs no more than the "tow rating" of the vehicle? - LanceRKeysExplorerReally, the best solution is to buy the trailer you like best and try pulling it with the 150, if your truck isn’t enough get a SRW 350. Towing will be easy again. Then, since you have a big truck, get a bigger trailer....
- philhExplorer III
Grit dog wrote:
Lots of newbs also get sucked into the “one too many bags of Cheetos in the truck bed and you’ll be a menace to the roadway and society in general” paranoia that is fairly rampant on this website and many others.
Typically processed by “experts” who have googled way more than they’ve towed....
You forgot, and will be sued by every lawyer in the county when you crash into grandma going to church.
I've towed at gross, and was probably over. Towing under capacity limit is a less stressful experience. I was surprised at the difference "E" tires made on my F150 tho. - TomG2ExplorerBuy it and try it. Then come back on here asking about fancy hitches, suspension upgrades, and tires that don't feel "Squishy". Happens every day. Then start shopping for an adequate tow vehicle.
- Grit_dogTrailblazerLots of newbs also get sucked into the “one too many bags of Cheetos in the truck bed and you’ll be a menace to the roadway and society in general” paranoia that is fairly rampant on this website and many others.
Typically processed by “experts” who have googled way more than they’ve towed.... - JIMNLINExplorer III
KD4UPL wrote:
The truck's tow rating is correct but it's not that simple. You have to use your head and figure out the other ratings like payload and axle weights.
Good points. Lots of newbs get taken in by GVWR based payloads... especially on many of todays new gen trucks with high gvwr numbers. Even one ton srw and 3/4 ton trucks can have higher payloads than the trucks rear axle/tires/wheels/rear spring packs are rated for.
The F150HD did have a 8200 gvwr but those gvwr based payloads were far exceeding the F150HD 4800 rawr numbers. Even the newer 7850 gvwr with the 33xx lb payload overloads the 4800 rawr in many cases.
Tow rating cover all types of rv and non rv trailers. - wing_zealotExplorer
44,066 PostsLatest Activity: Apr 16, 2026
