Steve_in_29
Jun 18, 2016Explorer
mattyj wrote:Steve_in_29 wrote:The truck has a 6.7 in it , what is the mgwr of your 2007?
My 2007 F350 carries the 3000+lb wet-weight of our Outfitter plus passengers and items in the cab just fine with no suspension mods. I am even still slightly tail high with it loaded. Though my truck has slightly more load capacity then that 2012 since the trucks got a little heavier in 2008.
Is the 2012 the 6.4 or the 6.7 engine?
If you mean GVWR mine is 11400 with a max load capacity of 4300 lbs. The same year CrewCab had a gvwr of 11500 (due to CC being heavier then SC) and the same payload rating. Since my truck weighs right at 8k that means I have roughly 3400lbs of actual load capacity.
