kmbelt
Jun 18, 2014Explorer
2012 F250 6.7 opinions
Anyone have any info on the 6.7 diesel in the 2012 Super Duties. Good/Bad info? Reliability? Mileage? Etc.... I'm looking at this one. 2012 Super Duty
jus2shy wrote:
Only issue that I know about the 6.7 was a small batch in the first production run of the motor had problems with one of the cylinder heads and would drop a valve. But being that you're looking at a 2012, I don't think you'll have that issue.
Ford wrote:
Some 2011-2013 F-Super Duty vehicles equipped with a 6.7L diesel engine may exhibit a runs rough/misfire condition only during the exhaust regeneration process. This condition typically occurs on light throttle tip in between 64-113 Km/h (40-70 MPH), and will not set diagnostic trouble codes (DTCs). The concern may be intermittent and a knocking noise may be present during the concern.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Step 1- Did the customer indicate the message center displayed a Cleaning Exhaust Filter message prior to the concern?
Yes - proceed to Step 2.
No - this article does not apply. Refer to the Powertrain Control/Emissions Diagnosis (PC/ED) manual for normal diagnosis.
Step 2- Using Integrated Diagnostic System (IDS) or equivalent, retrieve DTCs from the Powertrain Control Module. Are DTC's present?
Yes - this article does not apply. Refer to the PC/ED manual for normal diagnosis.
No - proceed to Step 3.
Step 3- Remove the left hand cylinder head. Refer to Workshop Manual (WSM), Section 303-01.
Replace all eight (8) exhaust valves and valve seals.
