have a 2012 ram 1500 2wd crew cab and found a small 5th wheel 21 ft with a dry weight of 4040lbs and a GVWR of 5756 LBS. should my 1/2 ton ram be able to handle this? thanks
I saw such combo on the road last week, it looked very comfortable. You should investigate hitches first, you will need a sliding hitch and I have no idea if one is made for the mini-bed truck.
