djgodden's avatar
djgodden
2012 Ram 3500 SRW Towing Specs
I'm looking for the above specs... GVWR, GCWR, axle data... etc. Anyone know where these are? I found the 2500 info but can't seem to locate the 3500 info.
  • On paper, less than what you hoped for....
    In real life, more than you think!
    Is that a good answer??
  • So how do you weigh a truck that's just a picture in your imagination?
    Apparently you don't. But what you can do on your lunch break is use a DoD computer to log onto RV.net but not any Ram trailer towing/hauling webpages. So, it IS just a picture in somebody's imagination.
  • I was looking just for the numbers because I was at work (DoD computer) during lunch and they don't allow pdf to come through. Ya, dumb but it's the guvmnt.
    Found it when I got home...
  • I'm looking for the above specs... GVWR, GCWR, axle data... etc. Anyone know where these are? I found the 2500 info but can't seem to locate the 3500 info.
    I see you found it. Great.
  • https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwivuKb_6-PLAhWmtoMKHa10DIwQFggkMAI&url=https%3A%2F%2Fwww.ramtrucks.com%2Fen%2Ftowing_guide%2Fpdf%2FRAM.2500.3500.Towing.Specs.pdf&usg=AFQjCNEiochaE42F0y1Ie678O37bZXnbZA&bvm=bv.117868183,d.dmo
    Googled it, found it in 3 seconds. It's a PDF, about 2/3 the way through it looks to have 3500 data.
  • Scaled weight subtracted from GVWR is your load carrying capacity. If you have the 11.5 inch AAM rear axle it will be 11,000 pounds. But tire ratings will dictate what you can actually load the rear end to.
