blkdodge's avatar
blkdodge
2012 Ram 3500 throwing a P0191 code
It says fuel rail pressure sensor.
Possible fix fuel filter or sensor.
I replaced fuel filter and disconnected the batteries for about 20 minutes and code is still there.
Do I need to leave them disconnected for longer or will that not do any good.
Code never went away not even for a moment.
Any thoughts
David
  • With 100 miles since I cleared the code, it has not came back. Keep your figured crossed that the problem was the fuel filter.
  • I cleared the code, now time will tell if it comes back. I'm thinking this may also be covered under the emissions warranty. It's not 5years old and has less than 100K for mileage.
  • If the condition has been corrected, the code will disappear usually after 5 key cycles.
  • You may have a defective sensor.
    Also you may have fixed the problem but the system has to go through enough drive cycles to clear the light. It may take 3 or more without the fault being present for the code to go away(light to go out) but it will be stored in the computer.
  • Check for a loose wire on the fuel rail pressure sensor. If no dice then it's time to visit your Ram dealer.
