- N-TroubleExplorerMy SLT crew has no back door storage
- ksssExplorerI have storage in both doors (crew cab), its an LT trim.
- N-TroubleExplorerMy biggest gripe with my interior is not the lack of “bling” but the lack of useable storage. It was just not well thought out in this regard. Hell you cant even store anything in the back doors. Would have cost another $2 to form some storage pockets into the doors but some bean counter must have said no.
- ksssExplorerWhat I have come to appreciate in the GMT900's is the interior. Not that it is all that nice, but what it misses in bling, it makes up for in durability. At 140K I have had to replace one vent actuator. My 800's while more comfortable and prettier, were not as durable. I like that it ages almost without signs of wear. Only the black wearing off the fan speed button, and a shiny steering wheel is there any indication that it has that many miles. The seats are just as supportive and intact as the day it was delivered. Mechanically this 08 has never missed a day of work. Just a solid rig.
- L3ExplorerYeah, noticing the Silverado 2500 and 3500 isn't much different. Rear spring is different changing payload rating? Pulling specs from VIN says 15,800 max fifth wheel/4175 hitch weight. Seems contradictory to their published GVWR. Guessing my camper could be closer to 13,500 loaded with a pin weight of 2500 - 3000. So looking at GVWR the truck doesn't have the payload capacity. If you do the math on weight of the truck compared to axle ratings, plenty of payload. And well within the rating for fifth wheel towing. Crazy. Still think this truck would handle it fine.
- Grit_dogNavigatorOr you'll be fine because it's identical to a 3500 minus a little rear spring rate. (Not as much as the gvw appears to indicate either.)
- N-TroubleExplorer
sayoung wrote:
LowRyter wrote:
IIRC, my 04 DMax is rated at 15k for 5th wheel. 12.5 for bumper pull.
My 03 2500 CC longbed was 15k for 5er & pulled/stopped our trailer fine. I think the 2012 2500 is 17000 on 5er.
Dont read too much into those 5er ratings. You’ll be way over payload ratings with a 15klb 5er. - Grit_dogNavigatorYup, good truck. Best combo for a diesel that year IMO. Standard used vehicle concerns or inspection notwithstanding.
- sayoungExplorer
My 03 2500 CC longbed was 15k for 5er & pulled/stopped our trailer fine. I think the 2012 2500 is 17000 on 5er. - LowRyterExplorerIIRC, my 04 DMax is rated at 15k for 5th wheel. 12.5 for bumper pull.
44,025 PostsLatest Activity: Feb 18, 2025
