H2oSprt wrote:
Thinking about buying one of these and moving to a 25' trailer instead of a truck camper. What are people towing with these? Any issues?
Thanks!
Yes, the Sequoia is a fine tow vehicle if the trailer you select is within it's limits. SUVs generally have lower tow ratings than pickups because they are heavier. I've got the pickup version of the Sequoia, ie, the Tundra and have been very satisfied. I would also recommend you consider the 5.7 V8 only and not any of the smaller engines as the gas mileage is not much different. The 5.7 with the 6 speed trans is a great combo. Do your research and make sure the trailer you pick is withing the payload rating and you'll be fine. Make sure you have a good quality WD hitch too.
