catfishmontana wrote:
Cummins12V98 wrote:
Huge difference!
Brakes, rear diff, front axle disconnect, air induction, dual radiators, new high strength frame, more hp and tq, higher tow and carrying capacities and so on!
I don't think all those carried over to the 2500.
Well I believe a few items did but certainly not all of them.
Main difference between the 2012 and 2013 2500 has to do with the engine components like DEF, dual air induction locations, dual radiators. They also upped the GVWR. I don't believe you can get the new 11.8 rear axle or the Aisian transmission, or the bigger frame with the 2500. I believe they only have the 3.42 ratio also where the 3500's offer the 3.73 and the 4.10 in the DRW models.
There is finally a difference between a 2500 and 3500 other than the rear spring pack.
