wintersun wrote:
Cummins12V98 wrote:
Huge difference!
Brakes, rear diff, front axle disconnect, air induction, dual radiators, new high strength frame, more hp and tq, higher tow and carrying capacities and so on!
The new frame is only provided on the 3500 trucks. Ram like Ford makes different 3/4 and 1-ton trucks. With GM the only difference is the rear rotors are 3% larger and an extra set of leaf springs is added to the 1-ton trucks. Payload capacity for the 3/4 ton Ram is about half that of the 1-ton SRW trucks which is similar to Ford. With GM some 2500 truck configurations have a higher payload rating than some 3500 trucks - devil is in the details as the saying goes.
I would not assume that you get everything with DRW with the Ram trucks. This is definitely not the case with GM trucks where with DRW you lose Stabilitrak electronic stability control and you lose trailer sway control.
To get ALL the options you need a Dually.
