Tiggs
Jul 12, 2014Explorer
I'm looking into the Bilstein 4600's, both front and rear. It looks like the only thing Bilstein makes that will fit my vehicle.
My tires are Bridgestone V-Steel R1B 265's, Load range is E and the max pressure is 90 psi on the tire. The door panel lists my pressures should be set at 50psi in the front and 80psi in the rear. I checked the owners manual and I don't see any recommendation to lower those pressures. Wouldn't lower than stated pressures cause tire overheating and risk damage to the sidewalls?
