TrekkerB's avatar
TrekkerB
2013 Chevy Express 3500 vs. Jayco 32BHDS?
We are hoping to purchase a new travel trailer in the near future and just wanted to get some advice concerning the tow-ability of our proposed TT. We tow principally in the southeast with trips of 1-2,000 miles freeway use. We do not dry camp and mostly haul with tanks empty. I do try to keep speeds under 65mph.
First the details, our tow vehicle is a 2013 Chevy Express 3500 with the standard wheelbase of 135", it has the 6.0L combined with the 6 speed transmission and the 3.42 rear end. Curb weight is 6087#'s with a GVWR of 9600. Payload is 3513 according to our VIN. Tow rating is 9700 with a GCWR of 16000. Our van has a Curt V5 receiver and is wired with a Prodigy P3 brake controller. No hitch yet, but am looking at either an Equalizer or Dual Cam.
We have been looking at the Jayco Jay Flight 28BHBE which I believe that our van will handle without a problem, but we really like the 32BHDS better. The problem is of course an extra #1,000 plus a couple of feet longer. Am I crazy to even consider this?
Here are my calculations:
Van 6087
Camper 8200
People 500
Cargo 1500
Total 16,287 which puts me right at (slightly over) GCWR.
Payload shouldn’t be a problem, but not sure about the rest. The extra length gives me concerns as well. What do you think? Is it doable without making the towing experience miserable?
  • If anything, you may find yourself keeping it under 60mph with the heavier trailer. You won't notice a few feet longer while towing. If the better layout is important to you, then getting to your destination a few minutes later won't matter much.
  • I think if you want the Jayflight 32 you will be a lot happier pulling the Whitehawk 32DSBH.
  • Thanks TexasATM.
    Nunya, I'm guessing some on the weight. I actually pulled up about 6 units on RVTrader and searched the accompanying photos for the dry weight on the yellow stickers. They averaged about 8,000#'s, I'm also adding a 2nd AC which will add another 100#'s or so. So my best guess is 8,200. If it's slightly more, I would have to be more careful in loading. The 1,500 cargo is also a guess based on others saying to figure 1,200-1,500#'s. We use a popup now, and load maybe 200-300#'s when camping. Even 1,200#'s sounds like a lot of weight for the things we will add.
  • Where did you get the numbers for the trailer? I have a 2014 Jayco 32BHDS and dry weight (just weighed a couple of days ago) is 8520 (metal sides, not fiberglass) completely empty. I have a 2015 F250 6.7L 4x4 crew cab. I am a gambling person, so if I were in your shoes, I would give it a shot. The problem you will have is going up/down hills. Flat, you will probably be ok. That 6.0 is going to be screaming up those hills. Most will tell you not to do it. Here are my numbers from my 2005 Chevy and then just a few days ago with my new 2015 Ford...
    Chevy
    WDH connected
    Steer axle: 4120 lbs
    Drive axle: 4920 lbs
    Trailer axle: 8100 lbs
    Total axle: 17140 lbs
    WDH not connected
    Steer axle: 3980 lbs
    Drive axle: 5120 lbs
    Trailer axle: 8040 lbs
    Truck only
    Steer axle: 4400 lbs
    Drive axle: 3600 lbs
    Total axle: 8000 lbs
    Ford
    Truck and trailer with WDH connected
    Steer Axle - 4580
    Drive Axle - 4800
    Trailer Axle - 7420
    Gross Weight - 16800
    Truck and trailer NO WDH connected
    Steer Axle - 4300
    Drive Axle - 5200
    Trailer Axle - 7280
    Gross Weight - 16780
    Truck only
    Steer Axle - 4800
    Drive Axle - 3480
    Gross Weight - 8280
  • I'd rock it in a heartbeat. The extra length will likely not even be noticed since the frontal area is the same on both units (so wind resistance will be roughly the same). I'm towing this same trailer with an F250 and don't have any issues. I've got a slightly longer wheelbase, but you've got more payload, etc.
    FYI, the 32BHDS is an awesome trailer.
