jerem0621
Apr 28, 2019Explorer II
What brand coil did you use?
I used Accell coils on my V10 and had no positive results.
Go OEM on the coils if you can afford it. When I start chasing misses I change the boots and springs and if that doesn’t work I replace the coils. It can be maddening to find the right coil that is missing.
I did use aftermarket coils on my V10 from a company called Uneek Supply and the coils performed great.
Also, and JMHO... I I put dialectic grease on the connections and I normally replace ALL of the boots and springs on my coils when I change the plugs on my Ford products.
As for plug gaps I just set them per the owners manual.
Also, the fuel filter may need changed. People don’t change them anymore it seems.
Thanks!
Jeremiah
Thanks!
Jeremiah
44,068 PostsLatest Activity: Jun 21, 2026
