boogie_4wheel
Apr 28, 2019Explorer
Start easy, swap #5 and #7 coils; regardless of the new coil let's prove the new one.
Was there any build up on the plug that you removed? Evidence of oil consumption?
Is this a cold misfire only?
Misfire when not under load has me wanting to think oil ingestion (stem seal), or weak compression. If the injectors are halfway easy to get to, swap their location as well to see if the problem follows the injector.
44,068 PostsLatest Activity: Jun 21, 2026
