patperry2766
May 01, 2019Explorer II
UUGGHHH...
The dark negative thoughts in the back of your mind that you repress, hoping they don't come true.....came true.
Took truck into the dealership. Have a misfire on #4 & #7 with 8% low compression on cyl #7. They are recommending replacing the motor to a tune of almost $11K. That ain't gonna happen.
So...
#1 go to independent and have them replace with crate engine or one from a junk yard and just keep chugging along hoping that the problem won't reappear again in 125K miles
#2, take to independent and have them do a valve job, hoping that's the only source of the low compression and it will solve the issue. If anyone knows a reputable mechanic in the Ft Worth Texas area, I'm all ears.
#3 trade it off
I don't really see a good way of getting out from under this problem best case for under about 5K, the truck is paid off. Should I take whatever equity I have, plus the money to fix the repairs and get something new? The local Ram dealership has some smoking hot deals on the remaining '18's 2500's & 3500's
Fire away
So...
#3 trade it off
Fire away
44,068 PostsLatest Activity: Jun 21, 2026
