turbojimmy
May 01, 2019Explorer
mich800 wrote:patperry2766 wrote:
UUGGHHH...
The dark negative thoughts in the back of your mind that you repress, hoping they don't come true.....came true.
Took truck into the dealership. Have a misfire on #4 & #7 with 8% low compression on cyl #7. They are recommending replacing the motor to a tune of almost $11K. That ain't gonna happen.
So...
#1 go to independent and have them replace with crate engine or one from a junk yard and just keep chugging along hoping that the problem won't reappear again in 125K miles
#2, take to independent and have them do a valve job, hoping that's the only source of the low compression and it will solve the issue. If anyone knows a reputable mechanic in the Ft Worth Texas area, I'm all ears.
#3 trade it off
I don't really see a good way of getting out from under this problem best case for under about 5K, the truck is paid off. Should I take whatever equity I have, plus the money to fix the repairs and get something new? The local Ram dealership has some smoking hot deals on the remaining '18's 2500's & 3500's
Fire away
An 8% variation on cyl 7? Without further diagnosis I am not sure that is enough to through the engine out yet.
Yeah an 8% variation isn't enough to worry about. 10% is a good rule of thumb but I've seen worse variations in good running engines.
My money is still on fuel delivery. Just sayin...
44,068 PostsLatest Activity: Jun 21, 2026
