carringb
May 01, 2019Explorer
You simply a power imbalance the most at high-load / low rpm.
When you take it somewhere else, let the know you already had a relative compression test done, and want a manual compression test on #7 (the #4 is probably just an artifact caused by #7). And also a leak down test, which will show which valve is leaky of that's the case. While they're in there, they should stick a borescope in that cylinder, and see if there's any crud hanging onto that valve causing it not to seat fully. It might just need a machined-dosed carbon cleaning!
44,068 PostsLatest Activity: Jun 21, 2026
