AlmostAnOldGuy
Apr 29, 2017Explorer
Regarding the integrated trailer brake controller...
Per the manual they say to adjust to where you can lockup the trailer brakes by manually throwing the controller to max brakes. I forgot the exact mph, 10 or so. I have no problem locking up the brakes on my tandem axle unloaded at about 7k.
I would check the trailer brakes. You can also check the voltage recorded at the connector. I am not sure what the expected voltage would be, maybe 10 volts. Per eTrailer they just indicate the circuit tester light is bright.
Good luck,
Stu
Good luck,
Stu
44,071 PostsLatest Activity: Aug 30, 2026
