2012Oudoorsman
Jun 03, 2013Explorer
APT wrote:Golden_HVAC wrote:
The Ecoboost is rated at something like 11,500 pounds maximum, but that is when there is no passengers in the truck, nor cargo in the bed.
Only the max trailer towing package ones, and GCWR is over 17k pounds for that package. Otherwise, some tow ratings are as low as 8000 pounds depending on cab/bed/axle ratio. His is 9700.Payload sticker 1162lb...I figure our family with dog= 550lbs and 150 lbs gear max.
That's your limit. 1162-550 for family+dog is only 612 pounds for trailer tongue weight with an empty bed.
Plenty of engine, power, and even wheelbase. Not enough suspension/payload for family + 900 pounds of TW.
X2 on this. You asked if you were going to be legal. Depends on how your state looks at things. Some states only look at axle limits but either way you will be over your ghee with that truck, which is ford will use for warranty concerns
