MitchF150
Sep 07, 2016Nomad
if you have it in "tow/haul" mode, the transmission will do that on the downgrades. Each time you press the brake, it will downshift 1 gear. It'll do it on it's own too, if it thinks you are going to fast..
I don't really like that feature, because most times, I don't need that much engine braking on the downside..
So, I disengage T/H mode on the downside. If I need to downshift, I just do it manually.
Good luck!
Mitch
Good luck!
Mitch
44,071 PostsLatest Activity: Aug 16, 2026
